Antec 900
grandgotti
Guys,Are there any Antec 900 owners here?Trying to find-out all my options with this case from someone already using it?
Clint
I'm fairly certain we have a couple of 900 users. I'll let them answer but I know I've seen them around the forum before! You might just do a quick search on Antec 900 and see what comes up, also might try perusing the rig gallery :)
Cheers!
While i dont have an Antec900, i can tell you that Antec are great themselves. Had to RMA a P160, they was great :)
name='llwyd' said:
Ah yea so it is, sorry, they looked the same
Sacrilege! Yeah it is a Stacker 830 and the Antec 900 is nothing like it rofl. Are you looking to watercool further down the track grandgotti? If so, stay away from the 900 as they are a right pita to plumb for a watercooled setup according to all accounts...Cable management can be a right sod too
Naw,For the 900 only fans!When,I start-up my new Intel rig.It'll be water-cooled,E6600,and a great intel mobo.For the intel rig;for my PSU.I'll be using a 700-800watt psu.Most likely PC & Cooling/OZC/Thermeltake Tough Power/SilverStone/or Seasonic
Going to put two bfg 7950GT's in the new rig!
name='grandgotti' said:
a very good gaming case for sure.
*coughmarketingcough* I played CS just as well for the ~2 weeks I was running my PC out of a motherboard box ;)
They look like solid cases, although not to my taste really.
I fancy getting one of them.
Reckon it would look good with white sharkoon fans instead of the blue led ones ?
Cheers :)
