The_Lanbone
Greetings all! First time posting after a few weeks of trolling the OC3D forums unregistered. Lovely site with TONS of useful hints/reviews/opinions...and now I'm calling on a bit of that to help me decide on my first real custom build.
Here's the scoop: currently running an OLD Dell XPS720 with E6750, upgraded 300GB WD VelociRaptor and GTX 465. Yes, I'm embarrassed too!
I've been doing my research and reading tons of reviews and this is the rig I've come up with so far, please tell me what you think:
Corsair Carbide 500R (White)
i7-2600k
Noctua NH-D14 (Anyone tried painting the fan housings?)
ASRock Z68 Extreme7 Gen3
Corsair AX850 PSU
Corsair Vengeance 16GB (4x4GB) DDR3 1600 (Changed up to 8GB of the low-profile kit now)
EVGA SuperClocked GTX 570 HD
Corsair Force GT 120GB SATA III (May come later to save some $ right now)
My only real concern is the mobo. I have seen and heard mixed things regarding ASRock's quality and customer support. I saw that TTL used one of their boards in the Bengal build which is probably a good sign but I would like to hear some more opinions from you guys. I'd like a board that will be slightly more 'future-proof' than the standard Gigabyte UD boards (ie: Ivy Bridge compatible, PCI-E 3.0). I like the fact that the ASRock supports multiple GPU's at x16 whereas most of the other options limit you to either x16/x8 or x8/x8 (keep in mind I will be transferring the GTX 465 into the new system as well to run PhysX as well as having another GPU to help out with Folding at Home (which I am obsessed with now! hahah)
I could probably get away with scrapping the SSD just to save a few extra bucks, so that is a little up in the air right now as well. Ideally I would like to add in a 2nd GTX570 later on down the road so having a board that has the bandwidth to allow all 3 cards to run at their maximum capabilities (yes, I know I will be losing performance when SLI'd).
Sorry for the long-winded first post. I'm really just looking for some advice, and maybe even a helpful push in the right direction to get this project started. Any and all help, opinions, experience is more than welcomed!!
Thanks guys!!!!
(Attached is my cart on newegg.com just sitting there taunting me! hahaha)
i7-2600k
Corsair AX850 PSU
Thanks guys!!!!
