Azurite
"If the word on the optical fibers is true, we are less than a month away from the launch of AMD's next high-end graphics card family based on its next high-performance GPU, codenamed "Tahiti". According to 3DCenter, AMD will launch new graphics card models based on this GPU around January 10, 2012. It is expected that we'll learn a lot more about these GPUs, maybe even come across AIB-branded graphics cards, at the upcoming CES event.
3DCenter compiled specifications of "Tahiti", based on bits and pieces of information from various sources. The specs can be listed out as:
4.50 billion transistors, die-area of 380 mm², built on TSMC 28 nm process
Advanced GCN 1D architecture
2048 1D processing cores
128 TMUs, 48 ROPs
384-bit wide GDDR5 memory interface, memory clock slightly below 1 GHz, target bandwidth of 240~264 GB/s
In Gandhi's words, salt is as free as the air."
source
You know Amd. It says 4,5billion transistors, but it might only have 2,6b.
128 TMUs, 48 ROPs
source
