xnax2802
Hi there,
I've just recieved my new Sabertooth to replace the faulty Crosshair V I had, but I've run into another problem.. The full story is as follows:
I ordered an 1100T along with a Crosshair V Formula, 8GB of HyperX Genesis RAM and a Corsair AX650 V2.. The CPU turns out to be dead on arrival and I get it RMA'ed.. When I then install the new (working CPU), the motherboard won't find the RAM, so I get a new motherboard, since the chance of it not being covered by the warranty would cost me close to two new boards..
So get the sabertooth and install it in my case, but when I get to moving the CPU, the heatsink just rips the CPU out of the socket and bends the end row of pins a tiny bit, while bending one pin in another end row almost 45 degrees.. At first I'm like "fuckfuckfuckfuckfuck" but I calm myself down and get the CPU loosened by using a blow dryer, and the severely bent pin straightened up using a small screwdriver and some anti-static as sort of a glove.. Anyway, I get the thermal paste refreshed and put the CPU into the Sabertooth, but when I attempt to get the heatsink intalled, it wont snap onto the board, and the CPU gets ripped out several times before I finally get it fitted, but then I think the fatality got played.. It's as if the CPU gets pushed slightly out of socket and snaps in again when i tightened the heatsink.. Now the board is telling me that the CPU malfunctions (of course) and I'm looking to get a new one, but the 1100T and 1090T apparently aren't sold in my country anymore, and I really don't know anything about the new FX series, so I'm sort of lost here..
So it's either to continue running AMD and sparing the cost of a new motherboard:
Phenom II's i can get a hold of (only going for the quad and hex Black Editions):
X6 1045T £106~
X4 980 £140~
X4 975 £127~
X4 970 £123~
FX's I can get a hold of:
8120 £167~
6100 £116~
4100 £93~
Or get a new motherboard (please give me some options, if you want me to take this one) with a 2500K (£174) on it OR saying "fuck it" and buying a whole new pre-built system with a 2500K and a GTX560Ti on a Gigabyte Z68X-UD4 in a CM Enforcer (all the other components included too, obviously) for £876~
Huge amounts of thanks in advance
X6 1045T £106~
X4 980 £140~
X4 975 £127~
X4 970 £123~
8120 £167~
6100 £116~
4100 £93~
