WYP
News Guru
A new AMD chipset is hitting UK store shelves.
Read more about AMD's A520 chipset hitting retail shelves.
Barely any VRM heatsinks on either of those two pictured motherboards. The TUF one also has that weird PCI slot placement. Once you install a graphics card, those bottom slots will be completely useless. What’s the point in them then?...
well the lack of VRM heatsinks could further support the "no overclocking" theory about it.
True, but using a high core count CPU, even at stock, may still be heavy for the VRM.
lol wut? clean your glasses.
Firstly you can't see all of the VRM. Secondly a dual slot GPU would cover one slot, leaving the last one clear. Though the mind boggles at exactly what you would want to put in a X1 slot other than a sound card or possibly WIFI card.
MATX boards are laid out like that. Some have two full length PCIE slots. The top X16 one, a space, then a second one. If you fit a triple slot GPU that is your lookout I guess.
All of that said you do realise the R9 3900 (not X, the OEM one that will be using boards like this) is only 65w.
How can you say it's the same as the TUF? When the top x16 slot is clearly lower on the TUF board, hence covering most of the bottom slots with a GPU.
Budget board or not - still an odd layout to go with, since you won't be able to use the bottom slots if you have a graphics card installed. At that point, what's the point in having them?![]()
That is exactly the same as the TUF, without the bottom full length slot. It's a £70 motherboard, dude. X16, X1, X1, X8?
Either way find me a use for all of those slots in a budget rig. Like I said, the two X1 are only good for sound or WLAN, because even fast NIC cards now are X4. So maybe you could fit a 5gbit LAN to that? but why would you in a budget rig? sounds kinda daft spending £70 on a board and then wanting to spend that or more on each NIC card and a 5gbit router etc.
Budget boards are just that. You put in a CPU and GPU and off you go.
I think whats hes trying to say (or I assume so) that if you are stuck having to use a GPU why bother including the X1 slots since they are unusable anyway.
In my opinion, I see more people using this motherboard with an APU and/or a very dirt cheap GPU that takes up a single slot and a terribly noisy fan... if those GPUs even still exist today. No one is going to purchase this and shove a mainstream/high end video card in there. It doesnt make sense, so that part I agree.
Because as he keeps failing to see they are not useless as only one would be blocked by a dual slot GPU. So that leaves one for, as I said a sound card or WIFI. Which let's face it you wouldn't be fitting. Why would you spend £70 on a board and then £50 on a sound card? you may as well buy a £130 board with much better spec.
Every single board I have, including my big old bastud X399 TR board has a slot blocked by a GPU unless you hoz mount a single slot water block. Only, nearly all good GPUs have a dual slot PCI bracket with crap on both sides that you wouldn't want to chop off (unless you're a div like Linus).
The LOLable part is that most use vertical GPUs now which block every slot lmfao.
Yeah. In a perfect world, GPU should be mounted flipped upside down, so not only are lower slots free from bulky cards, but we get to see the beautiful coolers/waterblocks instead of seeing the back side of a circuit board gathering dead skin particles
Speaking of that... if the coolers for the 3000 are anything to judge by, perhaps this is the Era of stupidly expensive dual side waterblocks! #droolandtakemymoneybitspower
Yeah man we touched on that with the "leak". If Nvidia really have made this card proper weird then it's going to require some serious blockery
Which means we won't see any cheap ones. I remember a couple of instances in the past where companies made custom cards with the power sockets wired on like, loose wires. Meaning the block had to have a place to bolt them to to hold them. GTX 670? or possibly something around that era? suffice to say the knock off companies made none. Mostly because they were still sat scratching their heads when Bitspower released their block lol.
Then again "we won't see any cheap ones" kinda sums up the 3000 series pretty damn well
Edit. I remember now !!! it was the GTX 295 dual PCB. Fookin nutty thing that was !
On a funny note, I remember seeing a GTX 295 for 4000kr (I guess £360 at the time) and laughed wondering who the hell would pay that much for one GPU. And hear I sit having forked out...£1300
Eh? are you smoking something today dude?
Yeah there is no "top slot near the IO". Look up. There's a M.2 there. Then we fit a GPU and what do you know? as I said, the bottom slot is perfectly usable, unless you fit some stupid behemoth triple slot GPU. Which again is out of context.
Again I reiterate, it is a budget board. As such why do you even care?
The layout is perfectly easy to understand. It is a budget board compatible with APUs and as such you wouldn't even have a GPU in there.
Would you like some cheese with your whine when you look at this budget board too?
Well I can see that we fail to understand each other, you don't seem to understand what I mean entirely. Which is fine though.
Oh on the other hand, it has nothing to do with the M.2 slot between the CPU and top PCI slot. The MSI board I picture previously has one too, yet that top slot is higher than the TUF one.
That last picture of yours is an mITX board, which is smaller and is more cramped than larger boards. So not entirely sure why you linked that one?...
Anywho, I'm off this thread.
