AngryGoldfish
Old N Gold
I've got plenty of those in stock![]()
I managed to find a used Vitus Sentier. Have to fix the front wheel though.
#offtopic #sorrynotsorry
Depending on IPC gains of 11th gen, they might become the marginally better gaming processor - if you look at reviews which supply worst case frame times / 1% lows, they're still rather competitive with Ryzen, though average FPS is a different story, and a much more marketable statistic.How the could Intel not do anything to counter this? (and the same to Nvidia)
Maybe the FBI should start snooping around in the back of Intels development department, looking for newly dug holes about 9 feet deep![]()
6 years on 14nm is just plain not good enough![]()
Depending on IPC gains of 11th gen, they might become the marginally better gaming processor - if you look at reviews which supply worst case frame times / 1% lows, they're still rather competitive with Ryzen, though average FPS is a different story, and a much more marketable statistic..
Well it helps to look at performance not through FPS but by frame times, from which FPS is derived from. Stable 60fps means that every single frame lasts 16.66.. milliseconds, but reality is that frames aren't evenly paced.Sorry, but I just have to ask, what are all those 1% lows etc that all reviewers put in their reviews?...
This presents three key metrics: Average FPS, 1% low, and 0.1% low. Because minimum and maximum FPS are useless outliers, we rely more heavily on 1% and 0.1% lows as our indicators of frame dips and lag. 1% time low FPS means the average of the lowest framerates 1% of the time, a noticeable dip percentage when gaming.
So some reviewers post the 1% lows and .1% lows. 1% means that 1% of frames lasted a certain amount or longer, and .1% lows means that 0.1% of frames lasted a certain amount or longer.
Why this is meaningful is that with a decently performing gaming computer the average FPS does feel good already, but if there are frametime spikes, you do certainly feel that. Let's say a .1% low is 33ms, well that means you're dropping to 30fps every thousand frames. In a mouse controlled first person shooter that at least throws me off. And if one of every thousand frames seems like a rare occasion to you, keep in mind that you're ideally getting a hundred frames a second.
Well if you run a game for 10 seconds, and for 9 seconds you get 100frames per second, and then it freezes for the last second entirely.Yep, this is exactly as my thoughts on the matter... Chinese to me :huh:
