WYP
News Guru
AMD's R9 Fury nano has been pictured, showing that this powerhouse of a GPU will have a tiny form factor. MITX build maybe?
Read more on AMD's R9 Fury GPU.
Would make an awesome addition to a tiny LAN rig![]()
Please be Crossfire compatible with the X. Please !
Why, there is quite big difference in power and aesthetics?
such a cute card
I would imagine it would be surely?
I know but I feel it would still offer a substantial boost over one card and get me from my current high settings to ultra and or with hairworks etc![]()
That's not what people are saying on OCUK.
I can't fit a second Fury X because I don't have the bracket needed to hold the rad in. Alienware did not include it and I've had no luck on Fleabay etc.
I could fit a Fury but right now there's only the choice of one and I don't like it. It would look stupid with the Fury X. The Nano would be a simple drop in and looks similar in design to the X.
I'm sure some one will try it if you can and post the results.
well i was testing an r9 295x2 over the weekend with the Witcher at 4k and had no real impact on framerates.
From the look of it this isn't called Fury at all, just R9 Nano. So it could be classed as a 390/X range rather than a Fury.
Time will tell I guess !
Its an interesting card for small form factors I think. I hope the performance is there to build a mighty mITX system. How will this fare against say a 980 that I own now and plan on putting in my upcoming transition to mITX system. If you can only have one card, I would get the most powerful one I can afford.
I have a gut feeling inside me that this Nano will be unlocked to a Fury within weeks of launch.
It better not there is absolutely no way on earth that tiny cooler could handle a full fat X.
I would imagine AMD have lazer cut it any way, so unlocking won't even be an option.
