AMD FX8150 CPU Review
Yet another interesting nugget of information.
http://www.techpowerup.com/153567/AMD-to-Turn-to-TSMC-for-Bulldozer-Manufacturing.html
name="TechPowerUp" said:
AMD to Turn to TSMC for ''Bulldozer'' Manufacturing
AMD is rumored to be seeking ties with TSMC, Taiwan's premier semiconductor manufacturing foundry, for future manufacturing of its "Bulldozer" architecture processors, according to a report by DonanimHaber. This has two very distinct implications: first, AMD could be facing issues with GlobalFoundries 32 nm HKMG node, its de facto foundry for CPU manufacturing, and second, this could just be an obvious development of future low-power APUs based on the new x86 architecture being manufactured at TSMC, much like how current E-series and C-series APUs are.
Then again, AMD doesn't exactly have any APUs in works that use "Bulldozer" architecture for the x86 cores, rather, its successor codenamed "Piledriver". Another couple of important things to note here are that TSMC does not have a 32 nm bulk node (it was scrapped with the transition to 28 nm bulk), and its HKMG (high-K metal gate transistor) manufacturing technology is deployed rather recently. It would be interesting to follow this development.
Seems the problem could be Global Foundries and the fab process after all. Else why would they swich to TSMC? Could also back up the B3 stepping and shipping delay...
I'm guessing that will be for future chips. Different stepping revisions and other chips.
Anyway the problem with the current BD is not a fab issue if it was it would have been addressed already. Its the architecture thats the prob it wont matter who makes them. Better fabrication process will just make it possible for them to be clocked higher.
Yes. I think fab process and yield are one thing, stepping is another. Yield / manufacturing issues would have manifested themselves, I imagine, with lower base clocks and poor availability etc. that does not appear to be the case.
It's possible that changes to the microcode in the form of a new revision might bring some gains, but that doesn't help with the launch unfortunately.
After all if we think about things, the FX8150 has the following:
. A decent clock speed
. Generous levels of Cache
. Four modules with two "cores" each - sounds like a recipe for Hyper-threading on steroids.
We also know that the prior gen of chips were damned good, so I cannot understand why performance would be so...mediocre on their new architecture. I mean, the peeps at AMD are BRIGHT bunnies, they're not going to design a chip that performs worse than the prior generation are they? Ok, something could well have gone wrong, a bug in the microcode, some obsure driver or BIOS related issue that's strangling the chips potential. We only need to look back at cougar point to know that things CAN go wrong. Saying that, these chips would have been extensively tested, though I've no experience of how that works for CPUs.
The more I think about it the more confused I get really, something just isn't right with the FX8150 both performing WORSE than a 2600k (and 2500k in many instances) being more power-hungry, not overclocking as well yet AMD still asking what I would consider a premium price for a less than perfect part.
IF the FX8150 had come to market far cheaper, I mean under-cutting the 2500k here, then we'd all be saying AMD had gone for the price/performance sweet-spot once again, while building an architecture that will come into its own with the heavily threaded applications of the future. Additionally, I can't remember who mentioned it without checking, if Windows 8 is even better at threading and load balancing than 7 then the architecture might begin to prove its self. However I don't think it will in gaming applications so much.
I think it was DugDiamond who said that this was a chip more aimed at the server market, that would make a lot of sense. Lots of threads, none of them particularly demanding, should LIKE more "cores", though games tend to have one or two (or more sometimes) rather heavy threads in my experience. However, maybe I'm wrong, but I took these chips to be marketed at the home/enthusiast PC builder.
Time will tell I guess but I can't help but feel that the FX8150, and the range in general, should be perfoming better than we're seeing. If BIOS updates, new windows drivers, new chipsets or even stepping revision sees this chip trading blows (that HURT!) with the 2600k then that's great news for AMD and anyone who wants to see a competitive market. I just hope AMD can do something quickly.
I'm looking forward to re-visiting Bulldozer in a few months, after the dust has settled and we have the proper motherboard chipsets available to test, a few BIOS updates have been made available for the older boards and whatever drivers needed have been sorted etc. A bit more performance and a cheaper price might see BD based systems back on peoples wish lists.
I rambled again didn't I? lol
Scoob.
Tom, can you make the first vid when you're back up and running the Gigabyte 990FXA-UD7? I'm hearing some rumours there's a problem with the CHV, with some saying as much as a 30% hit in performance. Seems very unfortunate for AMD if this is true.
doubt it amd wouldnt have sent it out as the testing mobo... they are stupid but not that stupid
More to do with the black/red colour scheme or an agreement between the two companies than anything else probably. Thread on Tom's Hardware about it, worth a read:
http://www.tomshardware.co.uk/forum/315775-10-asus-crosshair-giving-biased-results-bulldozer
Edit: A frequent mention of an L1 Cache bug on there. Tells me there's definately problems with all the test kits in some shape or form.
http://www.kitguru.net/components/c...ition-8-core-review-with-gigabyte-990fxa-ud7/
It certainly appears to have better performance running on the 990FXA-UD7, not sure about other boards though. If it is a motherboard issue, than the AMD marketing department just did an epic fail.
http://www.hardwareheaven.com/revie...essor-vs-core-i7-2600k-review-conclusion.html
Hardware Heaven using an ASRock 990FX-Extreme 4 also showed significantly better performance, keeping in mind these motherboards are also a fair bit cheaper than the ASUS CHV, there appears to be a serious BIOS issue,
there are quite a few reviews about now... and after all has been said TTL was correct.
AMD's claims were highly exaggerated and over the hype over-anticpated
the top-of-the-current-range of BDs are only on par with a sb2500K.
intel's ivyBridge/2700K with SR-3 now seems to be the way forward for myself.
unlucky AMD, you have just lost another user.
BTW: i have also been given a quote for a dual-Opteron server... what a rip off - lol
EVGA SR-3 (when released) all the way FTW
Single threaded performance may be crap. But it does beat the 2500K and 2600K in some heavily threaded benches so you have to give it some praise. Just not alot
TBH I never thought it'd be close to the SBs but I would have thought it would be a big improvement over the 1100T. But amazingly its not.
I think i'm going to chance my arm and pick up a gigabyte 990fx board and a 8150 cpu as even if it turns out to be crap, could just use it as a server as 8 cores would help there. I think with the reviews without the asus board showing completely different results than the ones like toms, for me at least I think its worth trying it. (Maybe its just wishful thinking on my part that amd can compete with intel for better choice). Would be cool if tom had another board and would show a review of the cpu on another motherboard that is not an asus one just to see.
