WYP
News Guru
AMD today AMD shows their new 'ambidextrous computing" solution which will create ARM and x86 APUs chips which are pin compatible.
Dubbed Project Skybridge, this will allow users to have a motherboards that supports or runs both ARM and x86.
This design framework is a family of products on the 20nm process and will use Puma+ CPU cores on the x86 side and A57 on the ARM side.
They will feature HSA as well as AMD GCN (Graphics Core Next) graphics architecture and will be Android compatible, the first product from AMD to do so.
Though AMD’s meeting today was heavy on Seattle and what it means for the server market, the company has said that Skybridge will target the client/embedded markets and release in 2015, to be clear this product is not made with servers in mind.
AMD also talked briefly about its plans for 2016, which will see the company debut its own custom-developed 64-bit ARM core. AMD didn’t offer much information but said the 64-bit ARMv8 CPU core will be in servers and embedded solutions along with semi-custom and ultra low power client devices.
The ability to make boards both ARM and x86 compatible will be great for AMD entering the tablet market, with minimal effort required for manufacturers to build ARM or x86 based tablets without editing the design, apart from changing the CPU.
Source - tomshardware
