Haxorinator
Hello all! So, this is my first post being on OC3D
but I came here to present my issues.
TL
R Overclock frequency keeps dipping, causing hitches/stuttering in gameplay, benchmarking, etc.
Currently, I'm having (semi) poor results overclocking the Athlon 860K. Coming from Intel, overclocking here seems a bit more tedious.
Here is my build:
Obsidain 250D ITX Case
MSI a88x ac v2
Athlon 860K
8GB Kingston 1600Mhz
GTX 970 Reference (For ITX + I like the design. I know its Overkill but I got a good deal)
EVGA 430w 80+
850 Evo 250GB (OS + Priority games)
840 Pro 128GB (2nd Priority games)
2Tb External (Games i'll never play but have on steam anyway xD)
Anywho, It seems this board, a mighty "a88x" DOES NOT have voltage control -_- or if it does I can't seem to find it. There isn't a lot of info on this board so I can't confirm if it does or does not. I can't seem to overvolt or undervolt, even using AMD Overdrive.
My main issue is that I can overclock to about 4.4Ghz (can't go beyond or BSOD, thanks AMD lottery) and it seems stable. BUT stressing the CPU will nosedive the frequency to 3.5Ghz very often and it will stay there for a few seconds. I have noticed this in heavy threaded games where my performance dips HARD for a few seconds.
Here is an example (don't mind the wallpaper, its Nyan Cat if you're wondering)
Full Speed:
Dip:
I've tried lowering the frequency to 4.2Ghz, turned off AMD turbo and the SAME thing happens.
I overclocked the NB to 2Ghz to see if it would help (heard its about the max) and the same problem occurs. It seems the only way to not "throttle" is to run completely STOCK, but thats no fun, considering this is a "Black Edition" chip ):
Messed with the RAM XMP profiles and it doesn't seem to affect the CPU OC, so i'm running it at 2133Mhz.
No overclock on the GPU (I can't even fully harness the power 99% of the time) so It doesn't appear to be a power issue.
Gotta say, I'm a little disappointed in this chip. Came from Pentium G3258 OC to 4.6Ghz (traded my brother, and he sold my build) and it seems in my testing that this "little" Pentium outperforms this 860K in nearly every application and use ): though I heard otherwise from 860K users.
Am I missing something? Any tips or tricks to help me out?
TL
Here is my build:
MSI a88x ac v2
Athlon 860K
EVGA 430w 80+
Full Speed:
Dip:
