I cant stand the fan noise on my 1080 ti (evga sc black), this pc is my living room and I have also set it up as a plex server. Plex now uses gpu for encoding and I have ' family members streaming so it can use a fair bit of gpu power which = Noise
So after seeing TTL's review I ordered, also other write ups show it to be a pretty good performer as long as I don't get a duff unit. I have seen the stories of the faulty pumps, trapped air, no contact on the gpu die !!
Hopefully my unit should be good as these QC issues all seem to stem from early to mid 2017.
So if anybody has any tips for me and this unit id be really grateful.
Ill be fitting it in a NZXT Manta which currently has a X42 240 rad in the front, and my intention was to put the 120 in the top of the case, is this a good idea ?
Also, TTL mentions that these need to be topped up in his video, any ideas on the best way to do this ? Do I top up via the tube connection or on the pump ?
I'll post some before and after temps also when I get it installed this weekend.
