Alchemy LED Strips in Shinobi XL
GamerGirlAlice
i was wondering if any one has put Alchemy LED strips in a Shinobi XL Windowed case. i am upgrading the fans to have Spectre Pro LED fans (3x 230mm & 1x 140mm). i am wondering if its possible to put Alchemy LED Strips at top and bottom edges in the case by side panel to light case. also what length should i look for.
Thanks in Advance, GamerGirlAlice
dem spectre pros are pretty decently lit up. Might be to much light but best guess is measure the top and bottom of case and buy accordingly. I have 2m led strips on my switch and they make it almost all the way around the entire inside of the case and shes alot bigger than the Shinobi iirc they make 1m and 2 m lengths i'd get the 1m and even still you may have to double them back
ahh that's the thing, i was going order at same time. so don't have the case yet, but that's a concern i hadn't thought of pro fans being bright already
let me turn off my lights and snap ya a pic of my 4 140mm spectre pro leds in action.
ok say 1m strips the case is 557mm wide at the side. 1m=1000mm now that 557 is external measuement so for shits and giggles lets say inside is 500mm youd effectively have to double it back on itself unless it can be cut to length.
I'd say use the pro's and if it isnt enough get a led strip kit. My plans on mine are to at some point replace the white NZXT fans with more Spectre Pro's Been trying to hit up Bitfenix for a small sponsorship but it hasnt happened yet lol. Anywho once I get the rest of the fans changed out I plan on most likely losing the led strip.
