Air can or Air compressor
Cans are more effective but obviously only for a short period. I have used my compressor with a fine nozzle for cleaning cases and radiators but I wouldn't use it on electronic components in case of getting moisture in it. Buying cans gets really pricey that's the only downside and they all seem disappointing after a few uses.
JR
JR
I can get one 300ml can for R299 (short period of time) but the air compressor is R295 (long term).
Does the compressor get moisture a lot? I want to clean my case every 3 months so I thought one time buy a air compressor
I'm not sure we are thinking about the same thing when we say compressor. And saying R9999<giganticnumber>999 means nothing to me.
JR
JR
I dont think so because that is a portable pump for R299. (Sorry for using my currency but the price isn't the point of the thread)
The compressor i'm looking at is the Fragram Air Compressor 12V 150PSI and the the Electric Pump Air Compressor 300 Psi Dc 12v Car Auto Motorcycles Tyre Inflator vs the
Fellowes HFC Free Air Duster 520ml Can
If you can get an air compressor for a tiny amount more than a can of air then I'd go with the compressor, You do mean one of these right ?
I'll take third option, the vacuum.
I have some of these, and can place the hose on top and it becomes a blower instead of a sucker. Either way, make sure you don't over speed your fans when you blow them out. That includes the power supply and GPU.
Those mini-compressors can be quite noisy, so no late night cleaning!
Be careful using a vacuum cleaner as static build up can kill components. Not sure if the one Kong posted is ESD safe or not, they are usually quite expensive.
They should be grounded through the plug unless you are using a 1961 model.
Oh this age old question.. :lol:
Firm Answer: So long as the hose is grounded there is no static buildup, the vacuum I use has exposed copper rings throughout the hose and they're linked by a earthing strap that runs the length of the hose, the end attachment is a 12" silica rubber hose reducer which takes the standard 2" hose to a 1/2" end.
It's all well and good having one but nothing beats a complete strip down and clean with paintbrushes and good old elbow grease.
Yes DIce this one to be precious.
Doesn't vacuum cause static elecricity?
Yes, I watch a video on youtube and its makes me mad. But that's a small price to pay
Too much work and than i pay more for the vacuum
Works for me. CPU heatsinks are easy to do assuming that you are periodically cleaning them and removing to replace the TIM. GPUs are usually easy as long as it's not a reference cooler.
I have a Hyper 212 Evo and that doesnt look easy for me
Canned air can be bad for condensation due to the temperature drop of the sealed air.
If you can get a compressor get one with a vapour catching chamber, this is the safest way to use one. They can be picked up cheaply as an airbrush + compressor combo and if you want it for cleaning shit off your PC it'l be worth it in the end
Edit: Something like this is ample
I was thinking a compressor + thin nozzle would of been enough?
Nope.
I speak from experience, not just 'would have thought'.
They put the anti-vapour chamber in so as not to screw with your paint with water vapour that condenses when you compress/pressurise air, it's there for a reason dude.
Using a straight-up feed from a compressor bares just as much risk as a cold can of air...
Nope.
Okay, Thanks SuB I will get a compressor and Air brush combo.
Is there a cheap way of cleaning your pc from dust? (I always used the pump at the garage)
