Dawelio
Active member
Heya everyone,
So here will most likely be a quite tough question, but I’m wondering if anyone is aware of any AIO that is close to the below requirements?:
240 mm
Asetek pump mounting
As short tubes as possible (most are shorter than NZXT’s Kraken 400mm anyway)
Tubes must be on the side of the CPU block and must be able to rotate.
Non RGB
And here’s where I bet only Fractal, with their Celsius coolers, are doing this:
No extra SATA cable from the pump?... Is it only Fractal that has a single 4 pin fan cable off the pump head?.
The reason for asking all of this? Much easier cable management wise in the NCASE M1.
Thanks,
Dawelio
240 mm
Non RGB
Thanks,
Dawelio
