Ragnar_Mike
Originally, I was thinking of going aircooling for my upcoming system. I'm lucky enough that the budget has increased enough that where once stood a Hyper 212+, then a D14, now has the possibility of an entry level liquid setup. It's probably a smidge overkill for what I'll be using it as, but this will be my last big purchase system for a while and damnit, liquid is cool! I'm going to be cooling an i7 2600k and a GTX 570 (It's mainly a work system, heavy on rendering not gaming) so my current idea is to liquid cool the i7 and have plenty of airflow for the 570.
I like the XSPC kits, but I'm currently leaning towards the Arc Midi, and I don't want to take up both bays with a rez. I know they make a 120mm kit with a smaller rez, but I have seen XSPC makes some single bay combo res/pumps.
My main question is about the pump. What sort of flow should I be looking for? The XSPC kits have a 450 for the 120mm and 750 for the 240mm. Is that about right: 3-400 lpm per 120mm? If so then I'll porbably have to rethink the combo I saw because it was only 200. I'm probably going for a 240mm rez because of how nicely it fits into the Arc.
Anyway, some tips for an entry level noob looking to dip his toes into water cooling would be greatly welcomed.
