Hi
Complete newbie here, happen to have 2 prometeia Mach II's (one stuffed as I appear to have been partially scammed on ebay), bought a Althlon 64 kit many moons ago from EPC, never got around to fitting it. Just bought a Q6600 g0, thought I would have a go at fitting one - I have a 775 kit from an ebay purchase. Decided to practice on one of my other PC's first. I had a number of issues where the PC would refuse to even power up when the prommy head was on the chip, but as soon as I stripped it all off it powered up fine. Eventually I got things going, was trying to "force" the USB driver install in Vista when the PC shut off. The motherboard is dead (the cpu is fine), no marks on it but no beeps when I start it up. I followed the manual, so no grease etc - forgot about this board!!
So...a few questions after this novel:
1. What could have caused this? Condensation? Any typical things?
2. The sides of the prommy head were cold but the top was quite warm - is this usual?
3. The prommy head itself seemed to melt (?) a little - so that the top plastic came off and there is a gap where you can see down into the head. Did I do something wrong?
4. I put the sticky rubber stuff on any motherboard "bits" (technical term huh?!?) that were to be under the compartments back and front - good idea or not?
Problem is I'm a bit reluctant to try this again, can't afford to lose too many motherboards!! Any insight on the above would be great.
Cheers
Drew
Cheers
Drew
