Advice for my PC problem
BrunoFey
Hey guys, my name is Bruno, and my pc has a little problem with GTA 4 and S.T.A.L.K.E.R. Call Of Pripyat, and i dont know what it its exactly, but i think it's the memory and my hd that's kind old. But i would like to hear your opnion about it and about what i should put on. Btw, i just build my system again, before was:
Rampage II Extreme + I7 950
650 CM + 1 TB WD Caviar Green
XMS 3 6GB + HD 5970
Now it is:
Rampage II Extreme
I7 950 + H100
XMS 3 1333mhz 3 x 2GB
HD 5970 + Accelero Xtreme
AX 850
500R
2 x 1TB WD Caviar Green
So, why i didn't put a better memory and an SSD? Cause stuff here in Brasil, or Brazil as you say, it's REALLY expensive. My Case, here, is 500 bucks. There it is not even 150 dollars. That's like 300 bucks here, tops. It's ridiculous, i know, but what can i do?
So in GTA 4 and Stalker COP i have some lag, and one of my memory sticks is dead so i only have 4Gb, and my HDD has like 3 yers already, so i think that's the problem, cause you know, a HD 5970 with overclock and a accelero and a I7 950 at 3.8 ghz and a H100 on a 500r, i doubt that's a GPU or CPU problem.
I hope you guys can help me, thanks everyone :):) a pic from my pc: http://imageshack.us/photo/my-images/213/2012062719563315.jpg/
how old is the windows installation?
also isn't the i7 950 triple channel for memory? not sure if running it with 4gb will affect performance (never used the triple channel intels, but am sure someone will answer this question for me lol)
Yes, they are. And i think that affects, my windows is Windows 7, and that shit eats a LOT of my ram, so i guess that's something to add. It's 64bits, btw.
Sorry dude, this is posted in the wrong place, It should probably be in the software section under games... this section of the forums is for the website and things
