Additives + wc setup noob
cl0ck_ed
Liquid cooling Additive what to get?
I want something as cheap as possible to get a rough idea how much wc will cost.
So far i have a Laing D4 pump
And will be getting a Fuzion v2.
Masterkleer tubing
T-line and fill port.
Any Suggestions on decent rads that are cheap also.
I can get the HW Labs Black Ice Pro II Dual 120mm for £12 delivered. Is it any good for the price?
Any help will be much appreciated.
Ide say get a laing DDC pump? And wont XSPC tubing be adequate?
Thefuzion V2 would be a good choice, and as for a rad.. i think most 240mm rads are similar.. Ide say that £12 is a good idea unless you can afford a thermochill
Thanks, i've now ordered
Fuzion v2
8ft Masterkleer
2 yate loon high speed fans
PT Nuke
D4 pump
Atm HE120.1 but looking for a 240 rad as above or PA160.
