I'm just curious as to what others have got
I was surprised a couple of weeks ago when what I thought was a fairly bad chip suddenly managed to reach 2.5Ghz over the standard stock levels... naturally SuperPI and Sisoft followed...
Well the secret for mine was mostly in the RAM, which doesn't seem to run at it's rated speed of DDR500 without relaxing a few of the default timings (usually the command rate and the most typically changed latency values) so I guess that's up for warranty replacement, right?
Still I was wetting myself when I got to 2.75 with this chip, it's only a 3200. I don't even have a special cooler, just a crappy stock AMD one. *happy noises* I have to say uGuru and the 3rd eye were very important in this also!
I have screenies I could post of sisoft, but only if requested
EDIT: should add SuperPI it managed in 36 seconds, and sisoft indicated it was beating a P4-E 570 3.8Ghz in arithmetic and multimedia... considering that at default clocks it actually falls just behind a 32bit Athlon 3200 I think it's a good improvement!
