A slim case for AiO watercooling?
shizuka
Is there a slim console like case that were a AiO watercooling for the cpu, as well as a desent sized gpu fit?
well a 2x120 would be better, but a 120 would be good enough. Its actually for a friend of mine who is used to a laptop, for the size mostly. With a basic AiO 12cm it should allow for nice enough temps even under constant load, seen as he likes to run multiplayer servers that are quite cpu intensive. I thought it should be quite straight forward but when i actually look specifically for a case that is both slim and AiO compatible i don't seem to find anything.
Silverstone are going to release an updated version of their Raven RVZ01 that would fit your requirements :)
Yeah, I was about to say RVZ01/ RVZ02. Or, if you prefer clean looks, the FTZ01.
Do keep in mind that you're probably best off buying Silverstone's own TD03 Slim cooler, and you will need an SFX power supply.
Well its what i think he would want XD. He has brought up "tiny PC to put by the tv to stream from the laptop to what i suggested the nvidea shield but he doesn't want that. And he also asked about upgrading his laptop that i think isn't really worth upgrading because its too recent. Although maybe something slightly larger would allow for better cooling, it would already be a significant upgrade from a gaming laptop, seen as desktop cpu's run twice as fast for a start.
You want a PC to stream from the laptop?
Smart TV's can stream directly, you dont a second pc to stream media.
thx i'l tell him that, it is indeed a smart tv... The compact PC was also as an alternative to upgrading his laptop as it is not far from the best you can get already (core i7 4xxxx, gtx 760m) so the only effective upgrade would be a desktop or a waist of money XD
You have many options available for network streaming / sharing.
Adding a second PC into the mix will make the experience unnecessarily complicated.
