a posible...intel...
name='Eguy' said:
I remember my 560/660 was at 60-80C but it didn't bother me, thats what they are made to operate at
I thought Intel recommended under 65*C.
Most overclockers recommend under 55*C.
Mine is 44*C.
Mine r0x0rz the big one!!!
Mine is 44*C.
bleh 65 with teh stock HSF it never gets that way
You know it voids teh warranty if you use a aftermarket hsf? taht's teh ghay :D
enVias said:
How are they supposed to find that out!
They raid your house looking for aftermarket hsf do they?
nah, when you send in your cpu for an rma, they have you send in the hsf and it its not used they will know ;)
its just like how they know if a vid card is OC'ed
Easy, take off the aftermarken HSF, clean up the CPU, put on the stock one and leave the computer on for a couple of hours. Then take it all apart again :D
hehehehe, good plan, but what is the proccy dosen't work ;)
