A Corsair H100 in a push-pull config in a Corsair Obsidian 650D
WebMaximus
Does someone know if it's possible to fit a Corsair H100 with 2 extra fans attached to it in a push-pull config in a Corsair Obsidian 650D chassis?
If not, what do you think will give the lowest temp, an H80 in a push-pull config or an H100 with only 2 fans?
Thanks in advance!
//Richard
Pretty sure that unless both sets of fans are low profile that you would have to put the second set of fans on the outside of the case. If they did fit tho, it will be extremely tight to fit a identical set in.
What motherboard do you have? I know it wont work with the maximus iv extreme... Asus P6TD Deluxe just barely but is super tight...
Edit: as a side note, with that radiator for how thin it is, making it a push pull config isn't going to change your temps more than 1-3[sup]o[/sup] depending on your ambient air temp... unless your case has most of its airflow going out other places it won't help much.
i wouldnt waste the effort on the H80. the H100 in push/pull fits dandy! you'll just
want to pay attention to the VRM heatsink (if equipped) on the motherboard.
in essecense there is 85mm of room from roof to mosfet heatsink
(if equipped). 25mm for H100 radiator 50mm for two fans you have miles of room.
it when you used thicker radiators it can be a concern.
airdeano
Yes it fits!
I have one in push pull configuration on a gigabyte z68x-ud3h-b3 with no type of problem to install! I had a sabertooth x58 that made the installation a little bit hard because the 8 pin power conector it´s on a horizontal form on the top left of the mobo and i had to conect first the 8 pin cable to be able to install the h100! It made a little presure on the cable but nothing to worry about!
