chiewleong
i'm going to stick with air cooling 1st as i have a hype212evo. should i upgrade to phanteks TC14PE? Or can it be fit into C70?
i think i might get the C70 at the moment. easy to moving around and not that huge case... i dont need a huge case...
going to finalise my shopping list soon. should be in 1000euro.
Finally, I going to build my rig.
Below is my shopping list:
i5 3570K
MSI Z77 MPower
8GBx2 Axevir 1600 MHz M Power edition
MSI GTX670 PE/OC
Corsair AX750 or Rosewill Tachyon 650W Platinum (Need help on this option)
2TB WD AVGP or 2TB WD Caviar Black
Corsair Vengeance C70 or CM Storm Trooper (which is better for WC in 2 thick 240mm rad)
Dell U2312HM or S2340L (which one is better for gaming and movie)
KB and Mouse: Logitech G100 combo (owned)
Audio: Logitech Z623 (owned) and planning for headset Steelseries Flux.
SSD and ASUS XONAR D2X will be added in April or May.
WC will be in later of this year.
Comment and advice are welcome.
Thanks.
I'm looking forward to build this rig.
thanks for all the help.
i5 3570K
MSI Z77 MPower
MSI GTX670 PE/OC
Thanks.
