Dawelio Active member Jan 18, 2019 #1 Heya guys, Just wanted to ask you guys for your expertise, would an 8700K work ”out of the box” in an Z390 motherboard. Such as the ASUS ROG Z390-I GAMING, without the need of any BIOS updates/updating?... Thanks, Dawelio
K KingNosser Well-known member Jan 18, 2019 #2 https://ark.intel.com/products/133293/Intel-Z390-Chipset Yes unless there is some kind of budget board that is a weirdo
Dawelio Active member Jan 18, 2019 #3 KingNosser said: https://ark.intel.com/products/133293/Intel-Z390-Chipset Yes unless there is some kind of budget board that is a weirdo Click to expand... Not entirely sure what to look at on that link? :huh:...
K KingNosser Well-known member Jan 18, 2019 #4 click on compatible products and it will list all the CPU's that the Z390 chipset supports
WYP News Guru Jan 18, 2019 #5 It will. It's just like how all AMD X470 motherboards will work with Ryzen 1st Gen processors.
Dawelio Active member Jan 18, 2019 #6 KingNosser said: click on compatible products and it will list all the CPU's that the Z390 chipset supports Click to expand... Oh right, that simple. I will quite dumb right now. But thanks a lot! WYP said: It will. It's just like how all AMD X470 motherboards will work with Ryzen 1st Gen processors. Click to expand... Ah got it, so no BIOS updating needing in order to an 8700K to function properly in an Z390 motherboard then? Just install it and rock on?...
