TheCaptain
Hi All,
I recently bought a powercolor 7970 (non reference) and seeing that it's not running at GHZ edition speeds, I decided to flash the BIOS
I followed the following guide: *removed*
I downloaded the file in the link and ran the modified winflash executable. To my suprise, everything was flashed automatically without having the option to backup my bios first
As you can think, the bios didn't work on my card as I don't have a reference card. Problem is, I don't have a backup!
I decided to flip to my secondary bios, save that bios and install it to my primary.
The card is now working, but artifacts horribly.
The question is: Will I be able to RMA this card, seeing that it has the same bios on both my primary and secondary bios switch?
Thanks in advance
Thanks in advance
