7790 devil 13 vs gtx780/780ti
kurgan999
Hi all ,
i need your help, first i wanted to buy this gpu
ASUS GTX780-DC2OC-3GD5
or gtx780 TI ( which is more expensive than gtx 780)
than friend of mine is willing to sell his 7990devil 13 ( almost new in mint condition ) for less price than cards up cost(same price as gtx 780, less than gtx780 ti) .
I will use this card for work on 4k dell 32" monitor ( and devil look like better option cose have 5 inputs for monitors ) and 2nd 27" support monitor , and i need card that i can use and abuse 24/day , i will not use it for gaming ( maybe 1-2h / day i play games cs go and lol ) ... so i need picture quality and durability .
Ty in advance !
ps. i've got seasonic 1k w plat , sabertooth x79, i7 4960x and 4x4gb kingston beast on 2.4 ghz.
The devil 13 is a monster card! Would run 4K quite easily but then it should with 6GB VRAM and 2x 7970 GPUs.
Go for it! before he retracts from the deal :p
much, much better for 4k monitor than gtx 780 / ti
Hey TY ALL FOR REPLIES !
Some ppl asked me what for i need card, and here is what i wrote :
"well i am using adobe cs from time to time nothing special... basicly i am poker player who play a lot of tables , and i from time to time record my sessions ( than need rendering ) , also i am using team viewer to stream my games , also from time to time i can stream seassions trough twitch ... alos when i work with my coach i need to record those sessions ( and render after ) so if i record and do this things on 4k its going to be hell of a job, and it will take ton of time. and i dont have time to waste.
I need good gpu card to all those things work smooth on 4k display + as i said i am using 27" as a 2nd monitor, and there is a chance to add another monitor into my workstation(i have 4 monitros + w8 for 4k to arrive, so 5 monitors at my table right now) .
I would like to buy something that will do the job while i am using pc 12h/day 365 days/year so i dont need to think if something is going to lag or something go broke or w/e."
A 290P would be cheaper and better than any of the options mentioned.
The HD 7990s only have 3gb of VRAM per GPU compared to 4gb on the 290P.
The 290P is not quite as fast as a HD 7990 but is more robust @4K.
You say you don't want to use the system for gaming but if you changed your mind you could add a second 290P to get good performance at @4K.
GIGABYTE
Radeon R9 290X
is this model good enough ? or i need some other one ? ty and sorry for bothering :\
I'm not 100% on the Windforce 290X, but here are the thermals for the cards OC3D has reviewed. The MSI Lightning remains our firm favorite. ;)
