randomicity
hey guys. quick question (i hope this is the right section). i've been looking around the net for quite some time now, been seeing a lot of people using the 600t white with a noctua nh d14-- but so far, i haven't seen anyone with the same case and cpu cooler attaching side fans.
so my question is if i have a 600t white, and a(an?) nh-d14, and i attach four nf-s12bs on the side mesh, will the nh-d14 touch the side fans?
notes: i've seen someone attach a side fan to a nzxt phantom while having a nh-d14 as a cooler. it just barely fits, like a 2-5mm clearance. the nzxt phantom is 222mm wide (http://www.nzxt.com/new/products/crafted_series/phantom) and the dude used a 20mm thick fan. refer to this topic
on the other hand, the nf-s12b is 25mm thick and the 600t is 265mm wide. a bit wider than the phantom so i'm guessing it COULD fit, but that might be because of the wider space on the other side of the case for wiring.
any thoughts? thanks.
