New member here. Looking for some help on wiring in a power and reset switch.
http://www.frozencpu.com/products/10991/ele-739/UV_Illuminated_Vandal_Resistant_Momentary_Switch_-_16mm_-_Black_Housing_-_Dot_Illumination.html?tl=g52c343s1181
http://www.frozencpu.com/products/8733/ele-399/UV_Illuminated_Vandal_Resistant_Latching_Switch_-_16mm_-_Black_Housing_-_Ring_Illumination.html?tl=g52c343s894
These are the switches I purchased. Ones a latching switch and the other is a momentary switch.
I was planning on using the latching for the power button and the momentary for the reset.
I honestly have zero idea of what I'm doing and read that if improperly wired it can blow the led. I've scoured the net , forums, youtube and still can't figure out how to wire it. As well as how to make the leds only be on when the computer is.
Any help would be greatly appreciated.
