Sin0822 says:
TO Almost everyone: STRAIGHT UP:
Someone put in the manual and in the GBT BIOS that the Uncore should be equal or higher than the CPU Ratio, that is NOT, i repeat that is NOT going to help you in any way. Lower it in fact, lower it to 35x or even 30x to be safe, then OC the CPU and then start raising it once the CPU is stable. Most of you can probably boot into windows at 5ghz and in windows OC the multiplier with GTL to 52x or even higher, I can, but the issue is I can't increase my uncore over 4.7ghz on air at all. That is a 500mhz less OC I can do on the Uncore than I can on the CPU ratio. The Uncore helps performance because it controls the speed of pat of the cache, however what I stated in my guide and what others don't really realizes is that the cache has double the bandwidth of sandy bridge and ivy bridge caches, which means that there is no reason to match 1:1, I recommend 300-500mhz lower on the uncore to unbottleneck it on air/water, on Ln2 it is better to keep it closer or on benching use the 300mhz if you can cool it. This uncore is not the same as it was on X58, it has a HUGE impact on system stability so watch out. Also only the recent GBT BIOSes can actually change the uncore(raise it over 39x) so if you have been setting high uncore before it wasn't actually setting that uncore. Thank you for reading this, now I don't have to repeat myself 20 times.
