Today I'm due to be getting my motherboard tray back from... well nothing has actually happened to it
. Anyway I'm getting my mobo tray back and I am hoping to get all my components back in my rig tonight and was just wondering what you guys would recommend.
My case is build in such a way that it was intended for 2 in 2 out with a big 200mm fan on the side panel (which I replaced with a plexi window). I have since added a completely custom roof panel to accommodate for a 360 rad which will come at some point...
This means that at the moment I only have 2 options for airflow really which are 4 in (from 3 roof and 1 front) and 1 out (rear) or I can have 2 in (rear and front) and 3 out (roof).
I will have my H60 on the rear 120mm fan mount and be using pretty much whatever fans I can find for the next few days while I get my please do not swear together as I would like my rig out of my current case as soon as possible.
Thanks guys,
Joe
Thanks guys,
Joe
