3rd party VGA coolers
Rastalovich
Just pretty sick of them claiming to fit cards that they don`t.
Latest Zalman VGA VF900-cu. "For the GF4 series, insert `nipples` into holes No.2". Holes No.2 are the closest ones to the gpu plate. The pcb has mounting holes in excess of the size of the Zalman`s largest spanned holes, buy a good 1cm.
Previous example HR03, in the compatability list "GF7600"... except for the one you have that has 2 spanned holes where all the others in the world have 4 holes in a different place, honest.
Another cooler to go into stock. Was going to have some fun with that 4200ti, nvm.
Awwwh, its okay mate. :)
Don't let a cooler get you down, although sounds like you have had a lot of problems with this kind a stuff.
Badly designed coolers.
