3hdtv setup Fail!
shabuko
Banned
Im having problem Setting up 3HDTV on my PC
it showing this on my screen resolution
http://imageshack.com/i/hlVGaT5aj
But when i use 3 asus vs228 lcd monitor it works perfectly fine by using this cables
mini display port - DVI
mini display port - HDMI
DVI - DVI
the cable setup for 3HDTV Since the TV doesn't have DVI Port
mini display port = HDMI
https://imageshack.com/i/exDZaAOGj
I also have some other ports like
mini display port - DVI that can convert to to HDMI
mini display port - Display port = HDMI
by the way, the HDtv that we have was a LG 39' Smart tv
https://imageshack.com/i/f0AzDv7hj
here is the specs of my computer
AMD Sapphire HD7990
16gb Memory
Core i7 4770k
Windows 8.
I have a similar problem, only my 3rd Monitor is a LED TV, I have to disable one of my monitors to use the TV as a display...
Also have Asus monitors (2)
Sorry I have no solution for this, just wanted to see if we could get some activity here.
