Hey Guys,
Can I get some input on the temperatures I am getting. I am not sure if the temps are any good. So I would like to see what other people's temperatures are with the same setup as mine. It is running at stock speeds and the room temperature is 19.5C.
Thanks.
IDLE TEMPS:
Distance to TJ MAX:
66 71 71 71 66 70
Max Temps:
32 31 26 27 35 30
LOAD(Prime95) TEMPS:
REALTEMP:
Distance to TJ MAX:
40 39 43 42 43 39
Max Temps:
54 54 49 50 55 53
IDLE TEMPS:
Distance to TJ MAX:
66 71 71 71 66 70
Max Temps:
32 31 26 27 35 30
REALTEMP:
Distance to TJ MAX:
40 39 43 42 43 39
Max Temps:
54 54 49 50 55 53
