360mm Rad. vs 420mm Rad.
CrissTM
Hi all,
I started buying parts for my watercooling. I got myself a XSPC X2O 750 Dual 5.25 Bay Reservoir, PrimoChill coolant UV Blue, PrimoChill clear hose 7/16 (16/11mm), 1/4" Thread Barb Fitting for 1/2" (13mm) FatBoy black.
Next on my list is;
- XSPC RayStorm CPU Block
- Alphacool NexXxoS NVXP NV 580/570 (for EVGA GTX570 SC reference PCB)
And here comes my dilema. Radiator, should i go with Phobya G-Changer 360 (60mm) or a MagiCool SLIM TRIPLE 420 MC (30mm)
All goes in a Silverstone Raven 2.
Thanks for ur sugestions
A 420 would be better than a 360 but you a can only fit a slim rad so you wouldn't be able to use the G-Cahrger.
