Hey everyone I just thought I might ask a few questions about crossfire and other such related questions
I am wondering if it is normal to have one gpu do 100% of the work while the other hovers around 30-60% ?
also my temps are quite high and was wondering if setting the fan curve in MSI AB to above 60% for each stage would be sufficient and if I would come into any problems with it?
At load my gpu 1 card has 85+ Celsius while my gpu 2 only reaches around 75-80 degrees. This is in games such as sleeping dogs with high res textures and War-game European escalation with its full range of DX 11 features.
I wont have any money for quite a while as I am focusing on my Tafe course so im wondering what I can do at the moment. My case is a cm storm stryker with its front 120's facing sideways. Should I change that?
I have also noticed that going from my OC'ed speed of 1200Mhz on both cards cores down to 950MHz doesn't affect temps at all so would this come down to a temperature probe problem or just the high room temps of 35-45 celcius ?
The computer itself is 3 days old and I have focused on trying to find the "sweet spot" for my speeds even though 1200MHz and 1575 memory clock is still stable at stock volts
