2900 pro and Zalman VF900
woppy101
my 2900 pro comes tomorrow does anyone know if i can fit my Zalman VF900 which is currently on my 8600gts i am going to put in my loop when i get another rad.
it cools my gts very well will it do the same to my 2900
many thanks
No, it's a lot better at keeping the heat out than 1900's, 8800's, etc. I get about 48C idle, 75C load @ 810/999
name='woppy101' said:
75c is still quite toasty looks like i will be getting the rad sooner than expected lol
Heh, you'd be surprised. Every high-end card since the X1800's and 8800's hit 75C no problem on stock cooling :)
did you take off your heatsink and put some as5 on
I put some Arctic Cooling MX-2 on, yeah.
90degrees is fine, anything over that then worry, but cards are made to withstand like 110degrees+, as long as it don't go over90 which shouldn't happen with good airflow then don't worry.
