240 vs 120 condensor
Ham
So ive found a nice radiator that is capable of being used as a condensor.
Would it be worth going for a 240mm over a 120mm for my SS?
Depends onthe size of the compressor, if its a worth to be condenser (as in can take the pressure) then you could most likely get away with quieter fans (using 2 isntead of one)
