[FONT="]I would appreciate your advice on the following.[/FONT]
[FONT="]
[/FONT]
[FONT="]I consider upgrading my internal hard drive. The most important aspect for me is performance. In terms of capacity, I’m quite happy with what I currently have (500 GB) as I can’t fill even half of it. I’d prefer to keep costs to a minimum so I don’t currently consider SSD drives. First, a little more information on my system:[/FONT]
[FONT="]
[/FONT]
[FONT="]Motherboard ASUS P7P55D PRO with SATA 3 Gb/s ports[/FONT]
[FONT="]Processor Intel Core i7-860 (8M Cache, 2.80 GHz)[/FONT]
[FONT="]Memory Corsair Vengeance DDR3 PC3-12800 8GB in dual channel configuration[/FONT]
[FONT="]Hard drive Western Digital Caviar Blue WD5000AAKS (SATA 3Gb/s, 7200 RPM, 500 GB, 16 MB cache)[/FONT]
[FONT="] [/FONT]
[FONT="]Which of these two options would give me more performance boost?[/FONT]
[FONT="]1) [/FONT][FONT="]1) 2 WD Caviar Blue drives in RAID 0.[/FONT]
[FONT="]The problem with this setup is that WD5000AAKS is no longer available in the local market. Currently the closest match to it is WD5000AAKX that has data transfer rate of 6 Gb/s. Should the drives in RAID 0 be identical? Will I have any problems with pairing these two together?[/FONT]
[FONT="]2) [/FONT][FONT="]2) 1 WD VelociRaptor WD5000HHTZ (SATA 6Gb/s, 10000 RPM, 500 GB, 64 MB cache).[/FONT]
[FONT="]
[/FONT]
[FONT="]Will the first option give me better throughput and thus more performance boost considering that SATA ports of my motherboard have only 3 Gb/s transfer rate?[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="] [/FONT]
[FONT="]
[/FONT]
