Ru5ty_t00l
hey all,
I recently joined this great community but I'm going to stay for long
as the title says I have two issues
while playing Syndicate and other games it suddenly crashes to desktop and a memory problem message appears.
I have 4 memories ddr2 2gb each. I have checked it with memtest many times trying to figure out if the memories or the slots or anything else. tested those memories on another board (other pc) and was OK . I run memtest for an other pair of rams on my board and errors appear again in memtest after 2-3 passes. all the errors appear at the 7th test (random number sequence). no O/C for this mobo. checked the voltages and saw that it's automatically set a little higher than it should. set it to manual and reduced to 1.8V. that seemed to work but not for long. errors appear again after a little while.
I also noticed that NB gets pretty hot . could that overheating cause the memories issue?
the other problem is that the cpu firsts core temperature is stuck at 49 celcious . I know that the 49 is not true temp and it only goes up to 50-51 when I stress the cpu.
could that issues be related one to the other?
