yeah the best cheap way to do it is wipe it and put the same large file on it on repeat, hundreds of times till it fills it delete and start again ... ive not been able to get anything off those after that
http://www.dban.org
Ok, so after staying up till 6am to fix this, I got it to workl on my pc no problem. So i formatted it and then I put windows 7 on it and it worked fine. I booted from the HDD on my pc many times but when I put it in the laptop it says it cannot find a bootable device ? Anyone know what is wrong with it or can help me at all ?
Have you tried a different hard drive in that laptop? May be an issue with the controller on it. Does the hard drive show up in the BIOS at all? It's not something as simple as changing the boot order to the proper drive, is it?
