1st Watercooling setup - help needed
devilgasdiver
Hi
I am planning on watercooling my new build with the following parts:
ASUS Maximus Extreme
Q6600 CPU overclocked (tide me over until the 45nm becomes affordable)
BFG 8800 GTX OC WC
this will be my 1st watercooled build and I have some questions
I have noticed the pricey Koolance systems and they look quite tidy but is this at the expense of performance?
I am keen for the whole watercooling setup to be as integrated as possible into the case, I don't really want piping running externally, so what cases/radiators etc are most suited to this.
The budget for the watercooling & case is around 350 GBP
any help would be appreciated
Thanks
Mike
Ensure you have at least a triple radiator... with fans moving at a bare minimum 40cfm to be able to cope with that heatload at a decent temperature.
Have a look around the various UK online stores... many can provide all the latest top-performing water parts prefitted for around that price (eg: HERE - v2KPro features triple radiator)
I have the set-up in my Sig for pretty much exactly the same set-up, it does a good job, my Q6600 never goes above 60*C, or i haven't seen it, except when i was running OCCT, but it's eating 1.525 volts.
name='maz1989' said:
the Thermaltake Kandalf LCS is only 150 and is a case + liquid cooling kit.
Don't go anywhere near a Thermaltake system... you could probably get better temps with a decent air setup.
Custom ftw :D
I am building a similar system. I'd suggest a triple rad if you can fit one. The cost isn't much more than a double anyway.
FWIW I am thinking of:
DDC-1 Pump (Acrylic top)
Apogee GTX
EK FC8800 Acetal top
PA120.3
3/8" tubing
My current system has 1/2" tubing, but it's a pain to route. The difference between 1/2" and 3/8" tends to be less than 1C, so I'm going to the more flexible option. I will be installing in a P182 with the rad strapped to the back.
Custom ftw :D
I'd be interested to know what goes into a TT LCS system, how come they are so bad?
materials used to make the kits and there pumps last about 10mins if your lucky.
take a look at any of the decent water-cooling stores and you will find none of them sell thermatake ;)
