ZanderKaneUK
Hi Guys and Gals
So I have been a longish lurker of the youtube videos and basically made myself a youtube account just so I could post a comment on a video, which has lead me to here.
I have been building, upgrading PC's since about "92" (back in 386/486 days) so I like to think I know my round the tech. side of a system build, but like many I have always wanted to do a water cooled rig. My almost 4 year old system some what on it's last legs (gaming wise) and a new build is calling. I am going to wait for sandy bridge since it seems to promise a lot from the what I read on hardware sites, but I believe it when I see it.
I wanted to go down the i7 route over that of i5. Last time I did a build is was Dual core vs Quad core and I went for the Dual core option because again from reading it seemed to suit my mainly gaming use of the machine. However I have seen my friends who got Quad cores get more longevity from their systems without over clocking Vs my fairly heavily over clocked dual core (2.4 -> 3.5) just to play BlackOps without the graphics (5870) stutter. Do the same arguments hold true for i5 Vs i7 as Dual Vs Quad?
I had planned buying the case and water cooling hardware now, get it installed and leak tested ready for the sandy bridge launch and then buy Mobo/Cpu/cpu block to finish the system. I have a 5870 carry over from old system, as well as a WD raptor.
So to my main question(s).
I had planned on using the Corsair 600T as my build based on this blog: 600T dual loop. So I started to look at the video reviews of the 600T 3Dgamerman, AnandTech, Heliux et al, and they seemed to say pretty much the same thing, until I found the video from tinytomlogan. He pointed out a few things that none of the other video reviews even mentioned which to me would seem fairly obvious and fundamental if you had the case in your hands. The guy from Heliux couldn't even get the front dust filter off LOL fail, so his review I took with a huge pinch of salt (kinda lost all creditability after that) Almost like a doctor who is telling you bad news and farts
tinytomlogan pointed out the Cool Master 690 II Advanced, which is growing on me but I am in two minds if two 240's will be enough for what I might want to upgrade too down the line (cpu, SLI/Crosfire, maybe chipset, currently it will only be CPU and 1 GPU full cover). So I started to look at the ATCS 840 since I could get a 360 in the roof and a 240 on the back of the HD bays.
I'm not on the whole band wagon of my machine has to silent, when it's on you can bet I will be gaming with a headset on, much more up my list of priorities is stopping dust getting in, annoying vibration noises and good natural air flow. I had thought I would do a dual loop with a dual drive bay res and pumps in one unit to save space, which I am finding hard to marry up, since the site I am looking at says use X pump with Y res but the picture of the pump has two plastic barb/pipes at the bottom of the pump, when surely the IN should be at the top of the pump from the res and the OUT should be at the bottom ( 8829 XSPC Acrylic Dual 5.25" Reservoir for Laing DDC with 8823 Laing DDC-Pump 12V DDC-1Plus (Swiftech MCP355))? The RP-450X2 Dual 5.25" Reservoir for 1-2 PMP-450/S Pumps seems a lot easier to figure out, which pumps to get? any opinions on both these res/pump combo's?
The rest seems quite straight forward:
Get the 2"/50mm radiators over that of the 1"/25mm since greater surface area equals better cooling, 1/2"/13mm barbs with hose clips over that of compression fittings with 7/16"/11mm tubing. I will have to wait until sandy bridge is released for CPU block? or is the promise of LGA1156 compatibility true? Which block to get?
Any other thought that I have missed totally?
Oh if you got this far thanks for reading
