1Gb VS 2Gb
Ravious
For BF3 if you want to play at 1920 x 1200 with AA and other settings very high, then you will most likely use more than 1GB. If there is only a £25 difference, then go for the 2GB version.
Yeah I play FSX the most and my 5850 laggs at 1920x1080p on high settings with filtering and high AA.
Thanks!
Your welcome mate
I doubt you will have any problems with a 1GB card but if you can afford a 2GB card then I don't see any reason not to buy one.
