jamesriley94
Hi,
i've gone through loads of different fans over the last few years, binned half of them as they were slightly too loud, or seemed to whine at me - ie - all coolermaster ones i've ever had went straight in the bin, thats how fussy i am
At the end of this month im upgrading from AMD to Ivybridge 3770k, with probably a 6970/7870 all watercooled. I've decided to go with the RASA 750kit, then add the extra GPU block, with an extra thicker rad in the bottom of my CM 690...so my questions:
Silence is everything to me, and I understand noctua fans are renowned for being the best, so I was going to kit out with 4 NF-F12s...but, with dual rads, I would definitely prefer LED fans, such as the Enermax Everests - although no idea how good they are - but, can they compete with the noctuas for silence?
Or, can anyone recommend to me any other SILENT LED fans, maxed out airflow is not a massive concern for me as I'm more interested in sacrificing a few degrees for silence, but, I currently have 4 antec tru-quiet fans which i have been very happy with, but I dont think they will be strong enough for rads.
Any help will be much appreciated.
I have looked into Phobya's LED fans, and Enermax's offerings, if ayone has any ideas on these?
Thank you
Thank you
