Hey everyone, so i have done some mild overclocking in the past, and this current chip is far from extreme, but it is more aggressive i believe, so i just thought i would run it by everyone to see if everyone else is comfortable. The chip seems very stable in prime 95, anyways here are the details. I have not tried backing off the volts at all, nor have i tried to go higher with current volts. Im pretty happy with 4 ghz and im not sure if it will really do anything but bring higher temps if i try to go further, i mean is 4.2 really much better than 4.0? I think i may notice a difference over stock as the 1100T does seem to bottleneck my GPU at times, but im not sure if its worth it to go for more than 4.0.
1100t @ 4ghz
251x16
1.47 v
1600mhz gskill
990FX sabertooth
NH-D14
PSU - XFX XXX PRO 750w silver 80 Plus
Visontek HD 6950
Temps
43C under full load 30 mins prime95
19c degrees idle
Night time winter santa cruz temps. Im sure it will be 5 to ten degrees higher when its summer and daytime.
1100t @ 4ghz
251x16
1.47 v
1600mhz gskill
990FX sabertooth
NH-D14
Visontek HD 6950
Temps
19c degrees idle
