Now lests see multiplayer...
You realize multiplayer results are next to worthless right? It will always be different every time you play and never consistent. Assume SP performance will be about the same as MP.
You proved me right lol
70fps Max in sp...
then you go on to say
mp 30-70
See that bold? Same as your single player![]()
fantastic way to get a new generation into pc gaming, quite impressive to buiild a gaming capable rig for that little money, so what if ya cant max things out, still a good starting point
Corrected your youtube tags.
Singleplayer fps is actually LOWER than multiplayer in most cases, they used some extra effects in there that they didn't in multiplayer. but if you're just playing offline it makes no difference.
Please use correct tags in your future posts, you can edit one of your existing posts to figure it out.
Cheers
I gotta ask, I've seen this posted somewhere before, maybe last week? Was that you?
Volts wise it will depend on your cooler - 1.45 is pretty safe but temps will be HOT.
Overclocking the Q6600 is a dificult beaty though because you have the play with the NB (and keep it cool) as well as many other things
In bf4 the ps4 runs at 900p at low/medium settings at 60fps. Just shy of your results. Xbone is a joke though.. 720p 60 fps at low settings.
Your gameplay would be in the 1050p catergory yes.
Your card is DX10.
PS4 is running at constant 60fps with 64 players on multi but it has occasional dips everynow and then which is common on any system.
Once you get more money a small upgrade in money can gain you a huge performance boost if you go with a 260x or 270 from amd or a 650ti boost from nvidia.
