1.392 - 1.46vcore difference are idle
im not sure i follow tbh :|
are you saying you set it at 1.392v in bios and its hitting 1.46v under load or what? only that spike will be load line upping the juice to stop it dropping under load.
No ok ill explain bit better sorry
I set in BIOS: 1.38v
CPU-Z says it at 1.392v-1.46v
the cpu is at stock everything nothing OC apart from ram. as the boards cpu fan header is busted its being collected tomorrow and unless this spike business is on all ASUS board ill be getting the Formula 4 when i save up a bit more. But tome said that had Vdrop or Vdroop as well.
