H Ham New member Jun 17, 2007 #1 Just wondering if it would be worth me grabbing some 1/2" tubing and barbs too replace my 8/11 tubing. Is it really worth it?
J JN New member Jun 17, 2007 #2 name='Ham' said: Is it really worth it? Click to expand... Probably not tbh. If you re-build your rig then maybe consider it, but I wouldn't say that you'd see any benefits by changing, so imo its not worth the effort.
R robump New member Jun 17, 2007 #3 Im going with 1/2" but thats olny becuase im starting from scratch again Rob
L llwyd New member Jun 17, 2007 #4 What about the XSPC tubing i'm using? the ID is actually 3/8ths, rather than 3/8"s from the middles of the walls
Y Yeungster New member Jun 17, 2007 #5 name='Ham' said: Just wondering if it would be worth me grabbing some 1/2" tubing and barbs too replace my 8/11 tubing. Is it really worth it? Click to expand... You may find this thread a very interesting read. I certainly did! Clicky
F FarFarAway New member Jun 17, 2007 #6 And for those who cba reading the results are: 6.35mm quick fit = 50.11C 8mm barbed = 49.74C 8mm quick fit = 49.31 9.6mm barbed = 49.25C 9.6mm quick fit = 49.04C 11.1mm barbed = 49.01C 12.7mm barbed = 49.00C
W weihk New member Jun 17, 2007 #9 i have to say tho.....im glad 8mm ID has no more than 1c difference compare to maaaaahooosive 1/2'' ID..... i started 14months ago on water......and started with 8/10 hose....... not that i care much :O)
SuB The Webmaster Jun 18, 2007 #10 i went from the default innovatek tiny stuff to 1/2" and saw quite a few more than 1 degree C difference :S but i guess it depends on hardware used :S
A ai_01 New member Jun 18, 2007 #11 it will benefit (temp wise) if you crunch on everything thou, ex: good pump, 120.3 or larger/multiple, an up to date block, good air flow etc. then again real world performance i would highly doubt you would see any.
