Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
  #1
Old 24-11-21, 12:25 PM
tinytomlogan's Avatar
The Guvnor
ASUS ProArt X570-Creator WiFi Review
The ASUS ProArt Creator range is aimed squarely at those of you who demand great networking and reliable performance.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #2
Old 25-11-21, 10:15 PM
Ubersonic Ubersonic is offline
Newbie
Hi, I don't suppose you tested what happens if you put an M.2 drive in the second slot (bottom left) did you? As tghe manual is a bit ambiguous. It says if you have a GPU in the second PCI-E slot then the top slot drops to x8, and it says if you also have an M.2 drive in M.2_2 then the top PCI-E slot will be x8 and the second slot x4, but it doesn't say what the top PCI-E slot will run at if there's no GPU in the second PCI-E slot and an M.2 in M.2_2, does it still drop to x8?
Basically can you use all three M.2 slots without sacrificing GPU bandwidth.
  #3
Old 26-11-21, 12:39 AM
AMD Enthusiast
The first m.2 slot is running off of the CPUs extra x4 lanes, though limited to PCIe 4.0. The rest are off the chipset which provides 12 lanes of 4.0.
The other dedicated PCIe 5.0 lanes are 1x16 for either GPU or SSD, or 2x8. That's how the CPUs are set up so I would guess it works. Idk if Asus would change it especially on such a premium nice board.
  #4
Old 26-11-21, 12:10 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Now that is a pretty mobo !
__________________
= Steam/Origin/Uplay - Dicehunter =
  #5
Old 26-11-21, 02:50 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I have a X570 TUF. I have two NVME 1tb drives in it. As well as a sound card. And my GPU still gets 16 lanes.
It is confusing, but Ryzen gets extra lanes from the PCH. I felt really stupid, because I only populated one SSD slot thinking I would have my GPU at x8.
Yup. Really nice. Seems they're taking a leaf from Gigabyte's Designaire book. Which is good.
__________________
If you don't like what I post don't read it.
  #6
Old Yesterday, 03:03 PM
Newbie
Hi, thanks but I got a message back form ASUS, the second M.2 slot does indeed share bandwidth with the first and second x16 slots, so if an M.2 card is installed in the second M.2 slot then the first x16 slot will drop to x8 (as there's only x12 left to work with for the shared slots). Running the first x16 slot at x16 requires only using the first and third M.2 slots.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
