Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 11-05-20, 09:41 PM
intelmachine intelmachine is offline
Newbie
New case for i9 - 7960x plus rtx 2070
Hello ,
i want to upgrate my old case (problem with power on button) so I'm looking for good case with good air flow .I want to put asus x299 mark 1,inside 4x 3,5inch HDD + 1x2.5 inch SSD ,RTX 2070 and I9 -7960x.Also I don't wanna spend too much money (max 90-120 €).Now im using zalman z11 plus
What do you reccomend?
P.S Thank you all for your help
My PC:
Intel i9-7960x with cooler master MA610P
ASUS TUF x299 Mark 1
64 GB RAM - G.Skill TridentZ RGB Neo
4x1TB WD BLACK
1x480 GB Kingston A400
1xSamsung SSD NVMe 970 Pro
Asus Dual GeForce RTX 2070 Gaming Evo OC 8GB
  #2
Old 11-05-20, 09:44 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Helps if you give a rough estimate about your budget, saying not wanting to spend to much doesn't really give a clear indication of price range.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
  #3
Old 11-05-20, 10:09 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
What case do you have? a new power button is about 3 euro.
You've also missed the most important part dude. What board do you have? MATX? ATX? EATX?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
